configure pim state-refresh timer source-active-timer
configure pim {ipv4 | ipv6} state-refresh timer source-active-timer interval
Description
Defines how long a multicast source (S,G) is considered active after a packet is received from the source.
Syntax Description
ipv4 Specifies the IPv4 address family.
ipv6 Specifies the IPv6 address family.
interval Specifies a source-active timer interval in seconds. The range is 90–300 seconds.
Default
210 seconds.
Usage Guidelines
None.
The following example configures the interval to 180 seconds:
configure pim state-refresh timer source-active-timer 180
This command was first available in ExtremeXOS 12.4.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
